coilover keeps leaking
seems I have a problem shock. just as the title says, it holds the nitro fine but it has leaked the oil out of it 2 times in the last year. Anyone have any ideas on what would cause this? bent or damaged shaft? Last time I just replaced the seals, could are-valve be in order?
I would look at the wiper seal for the piston as it travels in to the housing. Wipe it down and see how long before it starts weeping. Also have you tried replacing the N2? is there fluid on the N2 side? if so you have an internal leak on the packing separating the N2 from hydraulic side. If that is the case you will want to buy a kit for each so you can have it on had when you need it.
R/
Will
