Dash message battery related
Andy5160
Any idea what this is about? Aux battery was replaced one year ago. Cold crank this morning was a bit longer than usual.
What throws me off is that I also have check engine light appeared at the same time.
Thoughts?
It’s the main battery. I have been getting that message for about a year now, especially when it’s a colder morning. Just to lazy to replace it lol
Thanks Steve !!! Ordering one now but when I get to install it another story !!
Okkkk. Main battery replaced with Odyssey and it starts great. Old one actually was expended and making boiling noises. The problems are in the two images below.
Thoughts? Aux battery is one year old.
Had aux battery replaced. Message on the dash is gone now. Last time I replaced it from the top. This time I did it from the bottom. For me it was easier to do it this way however here is the catch. If you look at the image of the batteries specifically between the two terminals you’ll see the “fins” so to speak on the odyssey. They won’t let the battery to go in all the way because of the plastic retainer inside the box where the battery goes. So I had to shorten the retainer and all is well.
Super easy. To have all the clips is a plus as most of them must be replaced while reinstalling the fender flare.
Update.
Voltage was at 14.4 and this morning it dropped to 12.9. That “A” start stop light is back .
Any ideas. Alternator is going?
Also had to use air compressor today but did it while engine is running
Update.
Sure sounds like alternator. Make sure all large connections are tight and that belt is tight.
