Coming together. Getting everything mocked up for now. Will make final adjustments/installations soon. Driveshafts ordered (went with 1 piece for now for the sake of getting it moving, will be getting 2 piece in the future).
Metal cloak control arms - we're at the end of our adjustability before becoming unstable. This is mostly due to these being a mid-arm kit and not a long travel kit. However, most long travel kits seem to have drop down brackets (mounting at the frame, pointing towards the ground) that would impede ground clearance, but we should be able to make do with this. 4.5" game changer. Because of this, the axle droop we had while installing the springs made them look like noodles. It gets better once the truck is sitting on its own weight, but man, this thing will be able to flex. My fenders are in trouble.
Also - the shocks we planned on using were significantly shorter than what was needed. I think once it settles, and with the weight of the winch/bumper, that should give us enough compression to run something, but I will need to order shocks with more than 30" of uncompressed extension length at least. Looking into shocks for a 6" lift. Might be coilover time.
We have not cycled the suspension or turned the wheel yet, but I'm curious to see how the top down/bottom up tie rod/drag link work and if we have stabilizer interference.
Cool having a truck where the tailgate comes up to your chin. But yeah, making adjustments as needed.
Edit: Springs and shocks giving us plenty of travel in the rear, but the front droop measured out to about 2 1/4". Needless to say, I have an EVO MFG front coilover kit on the way.
