OlderMan53
Been getting the electronic throttle control warning light always followed by ABS off light. Replaced all wheel speed sensors and the electronic throttle body and i am still having the same problem.
Any chance you remember exactly what the name for the plug was?did you check the wiring and pins on the plug to the throttle body? no bent or pushed in pins, no signs of corrosion?
had same issue on my 2010 JKU, bought a new plug, de-pinned the old plug and pinned into the new plug, no more issues.
The new plug did come pinned with about 8" of wire but I noticed the old plug was no longer holding a few pins in place, so I opted to to the method above versus splicing wires.
About 90% sure i found it. Thanks for the responseAny chance you remember exactly what the name for the plug was?
