Yeah I am, this is not my first jeep and none of my others blew oilIt’s leaking oil….
Sorry. I had to.
Seems there is some issues with some front seals leaking. Get it into the dealer, it may take a while.
It’s just confused or maybe just identifying as a leaker instead of a burner.Yeah I am, this is not my first jeep and none of my others blew oil
Lol Surely this is an attempt at humor.Diesel engines do leak easier than a gas engine does. But like Onlyone said get it to the dealer
Nope. Every diesel engine that I've had has leaked oil. I have only had one vehicle with a gas engine leak oilLol Surely this is an attempt at humor.
When I had a Diesel I used to tell myself… it doesn’t leak oil.. it just Sweats oil from all the hard work.Nope. Every diesel engine that I've had has leaked oil. I have only had one vehicle with a gas engine leak oil
Yeah just some are worse then othersWhen I had a Diesel I used to tell myself… it doesn’t leak oil.. it just Sweats oil from all the hard work.
The majority of them belong to the company's I was driving for so it didn't bother me it was their money I was wastingQuit buying lemons.
What was the issue with the leak. Have same model, and timing cover was the issue on mine.I have a 2021 jl rubicon diesel unlimited just turned 16,000miles and was under it and seen oil all around lower engine gasket and drips on bolt heads. What the hell is going on????
Yes reseal tighten bolts and changed the oil.....now it's leaking again ggggrrrrWhat was the issue with the leak. Have same model, and timing cover was the issue on mine.
Wow! Not feeling good about mine now. Still haven't gotten mine back. But, was told seal should be in tomorrow. After weeks of going back and forth. Already put 1,700 plus miles on new Mojave they let me use. I know if mine leaks again after they are done with it. Will be calling mopar for a new motor. I don't want this issue to continue to be happening to mine. Good luck with yours.Yes reseal tighten bolts and changed the oil.....now it's leaking again ggggrrrr
So they didn’t do anything? lolYes reseal tighten bolts and changed the oil.....now it's leaking again ggggrrrr
