KMC Tank anthracite wheels -15mm
As the title says I’m looking at getting the KMC Tank wheels in anthracite to break up the black on black and figure the anthracite will kind of match the grey in the hood decal and dash. I found them in -15mm to run with the 38” Nittos and that has me thinking about them so I can keep a little narrower track but not sure if they will clear the EVO coilovers. Just don’t want to buy the same wheels twice if you know what I mean
per EVO instructions:
Recommended wheel backspacing 3.75” or less (smaller backspacing #)
I'd go with Disciple Off Road recommendation, they would know (y)
That will be roughly 4.5” backspacing which will work just fine for the EVO coilover setup on the JT 👍🏼
Thank you sir and I’ll be calling you when I start putting the evo kit together, it has a Clayton kit now but thinking the coilover setup will be a lot better for most of my traveling off road. I’ll have lots of questions concerning spring rates just so you are aware lol
Appreciate it, just getting into the analysis paralysis stage at this point and putting together the final build for the Mojave and don’t want to do it over again lol
