GooniesForLife
Okay my friends, this is a topic that’s been drilled into the ground and repeatedly over killed ten times over. But hereeee we gooo again. Really just looking for a push in a certain direction.
I have a 2011 2 door and am in “phase one” of the build if you will. Currently purchased Tera 60 semi float front and rear with 5.38 and arb lockers both with big brake upgrades, 1350 Adams drive shafts front and rear which I have not gotten yet because I’m waiting on suspension decision hence the post here, and 37” MTZ P3 tires.
I will be upgrading the transfer case and will be adding hydro assist as well but my indecision thus far has been regarding suspension. I will be sticking with shocks and springs for now, coil overs and all the Gucci stuff can come later.
Essentially, I am torn on lift height and long or short arm. I know there are pros and cons to both as I’ve read and researched until my eyes have bled. I am leaning toward a 4” long arm and running my 37s. Thing is though, if you can comfortably (I use the term loosely because I know that it’s subjective depending who you ask) run 37’s on a 3.5” short arm lift, am I really going to see a noticeable improvement/difference adding the half inch and running long arms? Anyone out there with experience? Apologies for the long post here but I really want to try and get this as right as I can. It’s a lot of money collectively as you all know if you own a Jeep.
Side note, I understand the implications of doing a long arm when it comes to welding on brackets, potential tummy tuck, etc. basically just looking for a push in a certain direction. Thanks again guys. Cheers.
