The 5-speed transmission of my YJ (2.5L / 1992 / 110,000 miles) causes problems when the outside temperature is below 6 degrees Celsius:
Shifting into 2nd / 4th and reverse gear is difficult to impossible in cold weather.
At temperatures around freezing point, problems also arise when shifting into first gear.
The transmission oil has just been changed (SYNGEAR 75W-90).
After about 10-15 km it gets better.
In 2018 a ProComp K3061RXT suspension was installed.
Up until 2018 there were no problems in winter even at temperatures below 0 degrees Celsius.
The car has not been driven in winter since 2018. Now in winter 2024 / 2025 this transmission is causing the problems described.
I am not sure if this has anything to do with the suspension.
Does anyone have a solution? Thank you!
