Replacing headlight bulbs with LED bulbs.
To replace the headlight bulbs in my 14 JK with LED bulbs will I have to remove the front grille?
Yes, but it’s really a piece of cake. Shouldn’t take more than 20 minutes start to finish. I did the same with my JK. Just be prepared for other drivers flashing their high beams at you. The LEDs are bright and everyone thinks I have my high beams on. Whenever it happens, and it happens a lot, I usually respond with a polite flash back of my actual high beams. That seems to set them straight.
If people are flashing you, you need to adjust the lights better. Properly aimed, LED lights shouldn't bother anyone.
I didn't need to completely remove my grill.. Just the clips on top and it moved out enough to do the change. Also you can (and should) adjust the beam height so it the right height (less people flashing ). You'll still get some.
Umm, sounds like you might want to follow your own advice:
TECH TIP : Jeep JK Wrangler Headlight Adjustment
https://wayalife.com/showpost.php?p=48183
I would think it’s a bit embarrassing to have to “set others straight” all the time?
It really is a piece of cake to adjust your headlights properly. You won’t have to flash anyone or be flashed. You also see way better with your light where it should be.
I pulled the Jeep about ten foot from the closed garage and adjusted them from there my truck is roughly the same height so I just just that as my reference point. Now there are straight and haven’t been flashed. IMG_0012.jpgthey look amazing now. And I can see so much better now.
I pulled the Jeep about ten foot from the closed garage and adjusted them from there my truck is roughly the same height so I just just that as my reference point. Now there are straight and haven’t been flashed. View attachment 315214they look amazing now. And I can see so much better now.
I think your supposed to be 20ft away when adjusting them. Follow the steps in the link above really good information
