Beadlock thread stripped
Guascone
Today the tires shop changed my tires...I came back home (200km) and I checked the bolt torque...I noticed that one of the thread has bene stripped...now what I have to do?
Is there a way to repair my wheel?
A metallic insert?
[emoji24][emoji24][emoji24]
A metallic insert?
Shop needs to do the legwork to find out how to repair it. I would take it back to them and show them what happened.
A metallic insert?
Depending on the brand wheel you have, the inserts are replaceable relatively easy. It's a pain in the ass to be sure, but the process is easy.
Here's an old thread on the inserts for ATX Wheels: https://wayalife.com/showthread.php/22615-ATX-slab-beadlock-inserts-came-out!!-Help!
You are fully right!
I’m already in contact with the shop...they will pay for the repair but first of all I would understand if the wheel is repairable...if not I will ask for a new wheel...
A metallic insert?
I’m surprised you found a tire shop to work on beadlocks.
The beadlock wheels are becoming quite common in Italy( there isn’t a dedicated law that allow them or not) ...the tire shop is an official Bfgoodrich off road center...his owner is a jeeper and should now very well the job...I was hoping...
A metallic insert?
To answer your question, I’m sure that your wheel can be repaired. Whether that makes sense needs to be determined:
Cheaper wheels that do not have inserts can be fixed rather easily by adding a threaded insert. Helicoil repair kits are available for around $25 on Amazon and can be installed with low to medium skill level.
More expensive wheels can be a lot more difficult to repair. They already have threaded inserts and the damage is usually that the insert spun in the wheel so it’s not as simple as just replacing the insert. In some cases a plug style insert can be used like from Jergens, but these inserts are larger than Helicoils and depending on the wheel it may not fit or have enough supporting metal around the plug. If that is the case then the wheel needs to be welded which starts getting a little sketch as the welding may distort the wheel and is more labor to prep and re-machine the hole. This is when it might be better to just get a new wheel.
Either way, good luck and I hope your repair works out!
Thanks a lot for your very clear explanation!!!
