Cannot use Sway Bar Disconnect
Redtraillanai
Hey guys! I’m a new owner of Jeep Gladiator 2020 Rubicon. I have question about the Sway bar disconnect I couldn’t use them because of tire fill alert. I put my 38” tires on 20 psi. Also I have done doing the tire fill alert setting before deflation. I set it to 20 psi in uconnect screen. Its still giving me alert. Do you guys have this problem? I couldn’t use my sway bar because of the alert in my gauges.
Tire pressure should not affect sway bar solenoid motor function. Like stated above...were you in 4L? Is this the first time you have attempted to use?
I use mine in 4hi all the time. Did you install a tazer or something to reconfigure tire size and pressure warning settings? Try setting your pressure warning to a lower psi and try again. There might be some kind of safety thing associated with that, though I’m not sure why. People air down to 10 or lower all the time while wheeling disconnected.
