Bullwinckle
Damn good looking smoker!! There’s gonna be some great tasting food coming out of that thing…That it is. View attachment 365186
Both actually, but I was thinking about the firebox when I posted... I assumed the cook chamber will have some sort of damper on the flueOn the cook chamber side or the door side?
I don’t plan to add anything to the door as of now. For airflow I will just keep it propped open. I made the hinges tight so it won’t swing by itself even on an incline. I have a few ideas but it would turn out like shit without a CNC. The hole from the firebox to the CC is standard, I think I posted a picture. And the chimney will have a dampener that will swing side to side.Both actually, but I was thinking about the firebox when I posted... I assumed the cook chamber will have some sort of damper on the flue
I think that all sounds solid. Almost everyone I know that has an offset woodburner has to either re-do their firebox damper by making it bigger or crack/prop the door because they don't breathe good enough. They take a lot more air than I expected.I don’t plan to add anything to the door as of now. For airflow I will just keep it propped open. I made the hinges tight so it won’t swing by itself even on an incline. I have a few ideas but it would turn out like shit without a CNC. The hole from the firebox to the CC is standard, I think I posted a picture. And the chimney will have a dampener that will swing side to side.
Glad you like the inkbird. I’ve had it for a year and a half or so and not a fan. That stupid alarm is so fucking loud. The graph doesn’t save leaving you no was to track your cooks. Distance is good in straight line only. I can’t be in the garage and have the bbq in the back since it won’t read.Been a long time since I’ve done a chicken
Got a new thermometer, inkbird off of Amazon, 4 probe, Bluetooth. App is nice, good long connection distance.
Ah that’s a bummer, I dunno if they improved it or I’m just lucky but I can be pretty much anywhere on the property or inside and still connected. I don’t need the fancy graph features, I just need it to let me know when smoker is out of temp range and when meat hits the mark.Glad you like the inkbird. I’ve had it for a year and a half or so and not a fan. That stupid alarm is so fucking loud. The graph doesn’t save leaving you no was to track your cooks. Distance is good in straight line only. I can’t be in the garage and have the bbq in the back since it won’t read.
You should have a reality show “My 600lb Smoker Life’With a HighwayTrout consultation we got this puppy rolling.
View attachment 366360 View attachment 366361 View attachment 366362
I’m not quite at 600lbs. Couple years of eating from this and I might be. LolYou should have a reality show “My 600lb Smoker Life’
I was referring to your smoker…I’m not quite at 600lbs. Couple years of eating from this and I might be. Lol
Bitchen damper on the flueWith a HighwayTrout consultation we got this puppy rolling.
I know lolI was referring to your smoker…
Works perfect. Might not even waste my time fabbing a permanent one.Bitchen damper on the flue
Flavor on a wood burning offset if totally different and I think better. It’s a natural flavor that you won’t taste until you have from a stick burning. Heat retention on this is far better just due to thickness of the metal. Small differences. Not enough to make someone go from $800 rectec to a $4000 offset.Besides the coolness factor of making it (which is really cool by the way), what is the benefit of this over a garden variety RecTec or Traeger?
