OverlanderJK
Resident Smartass
That is literally the spot where the skin ends. I think you would have been more pissed if you had skins and still fucked up the body lol
And stop posting that picture. Makes me sad.
Dude. That sucks. Looks like the slider took the brunt at least.
You are correct and these do work with the EVO long arm kit.Based on these pics, the JL sliders weld (bolt-on) to the frame and not the actual body mounts. It bolts to the steel around the body mount in another pic. I could be missing something. But this is very similar to the JK frame mount sliders, right?
Mel has the bomber rockers on his diesel JT without the skins and for a while now. I haven’t seen him having too much of a problem with his panels getting messed up. One of the reasons I went this route. I’m sure eventually it could happen but I’ll take my chances for now. That is if I ever actually get out and wheel… lolRight. But I believe jet has the skins for added protection/stability of the bombers.
The skins are $300. So now you’re at $1000.
If you think I can pick lines like Mel, you are pulling too many doubles at work. Lol.Mel has the bomber rockers on his diesel JT without the skins and for a while now. I haven’t seen him having too much of a problem with his panels getting messed up. One of the reasons I went this route. I’m sure eventually it could happen but I’ll take my chances for now. That is if I ever actually get out and wheel… lol
For Sure... it was really that gap between the slider and the fender where the Rock slipped by... and me being overly aggressive before the spotter had a chance to get to the scene. lolDude. That sucks. Looks like the slider took the brunt at least.
LOL . Never thought of it like that. Well crap I’m in the same boat but too late now… Although he is still pretty rough with his rigs so you know it can still take a beating with that combo.If you think I can pick lines like Mel, you are pulling too many doubles at work. Lol.
Good to hear. Do you know if they will be selling a skin to replace the skin that attached to the slider on your JL? Hopefully it would have the same bolt pattern.I have to say that I'm surprisingly still happy with my bombers. I would prefer the frame mounted sliders but they have held up better than I thought.
If you don't mind, when you get a chance can you post a picture of the top without the insert?The only picture I have now but I got mine today. They are super beefy.
will doIf you don't mind, when you get a chance can you post a picture of the top without the insert?
They don't have stand alone rock skins for the JL/JT YET. I suppose you could use the bomber skins but would take some modifications. But there is a gap between the slider and the body so a skin SHOULD work.Does anyone know if they may be compatible with the EVO rock skins?
Thanks for the info.They don't have stand alone rock skins for the JL/JT YET. I suppose you could use the bomber skins but would take some modifications. But there is a gap between the slider and the body so a skin SHOULD work.
Thanks.will do
Not bad. Only like 2.5 weeks from release back in 2018.The only picture I have now but I got mine today. They are super beefy.
