Front Passenger Wheel well?
epriev
What is this for in the passenger wheel well? It looks like it could catch the tire at flex and turn?
Solution
I think I remember it’s supposed to help prevent the front tire from intruding into the passengers footwell in an accident. Don’t remember what year they started adding that.
Upvote 1
Solution
Looks like simply unbolting it will not fix the tire clearance. The is a tab welded to the frame that would need to be cut off. This tab is what looks to be what could rub or cut a tire, not the block bolted to the frame.
Upvote 0
Since it is apparently a safety feature there may be liability if you remove it (similar to seat belts). Or it may fail an inspection.
Upvote 0
When I took mine off. I took all the bolts out but one. The one on the inside. I backed it out as far as I could and cut the head off with a cut off wheel. Then I cut the part off the frame, cleaned it up with a flapper wheel, and hit it with paint.
Upvote 0
