Lagavulin
A friend of mine noticed a puddle of oil under my jeep. I checked it out and assume it is oil also but when I checked the oil level manually it was showed in the "safe" range and not in the "add" range. I checked all the other fluids as well and they all are at the correct levels. I started the jeep and checked the gauge and that read ok too. Then while running I visually inspected under the jeep and under the hood/around hte engine etc. I see signs of oil but nothing is leaking. Any clues on this? Places I should check or even change out? Thanks
