I'm not going to edit my original post with the parts list, but if you want to run the double lit switches-
V1C1J77B-00000-000 $9.50 each from Otrattw.com- these are Amber led switches. They have Amber, Red, Green, Blue or White led switches.
You can follow the rest of my writeup, but you will need to run one more wire to your switches for illumination. The illumination source wire is a small 20 gauge wire behind the power window switches in the dash. it is Orange/gray stripe.
Pin 6 connects to that illumination wire. Pin 7 and Pin 8 are tied together to ground. Pin 2 is the 12volt input from Fuse 6 in Relay Panel. Pin 3 is the switch output/relay input.
Here is switch off, Illumination On
and here is Switch On, Illumination On- switch output hooked up to Led rock light
