All finished guys here she is!! View attachment 73022 View attachment 73025 View attachment 73026 View attachment 73027 View attachment 73030
That looks amazing, I think I know where I want to mount my switches now. Looks almost like it comes from the factory that way. How big of a hole did you have to cut and what did you use? Also where did you get the switch housing from?
Looking good!
Awesome job Noroad! :thumb:
I just ordered a wireless controller for mine, so i can turn on/off up to 4 of the accessories with a remote.
This could take the place of having to actually mount switches, to give others an idea of what can be done with the relay panel, but i would recommend having actual hardwired switches versus only wireless.
The wireless controllers look to be cheaply made, which is good and bad. I got a 4 channel controller for $13. i figured it would be fun until it broke
I would recommend as Swank has on his- a 50 amp circuit breaker (i had the fuse holder already) but a circuit breaker is a better way to go, since it will reset when the overload is corrected. a fuse has to be replaced.
added 50 amp circuit breaker to parts list from waytekwire
Add up what you will have for all your accessories. 50 is common.
What size were you wanting to go with Dave?
^ thanks!
Kill Switch- i mentioned this at the start of the thread, and later on in another post- but the easiest way to do it is- interrupt the 12 volt wire from Fuse 6 going to the switches. You could bypass hooking it up to Fuse 6, and find a 12 volt ignition source instead (from the left side cigarette lighter). Then the switches would only be live when the key is on.
Or you can put a separate small toggle switch somewhere hidden (inside the glove box,etc) that interrupts the wire going to the switches (from fuse 6) so that the switches only work if that separate toggle switch is turned on.
I suggest doing a kill switch, especially when doorless, since fancy looking switches are a magnet to anyone walking by your jeep, it's like begging them to turn them on.
Otrattw has a 6 panel mount like that for $9.00- i believe this is which one he used
or
waytekwire has individual pieces that snap together to make how ever many switch locations you want.
The End pieces are- 44387 $0.95 each
The middle pieces are - 44388 $0.99 each
i believe you have to order a minimum of 5 each
Great job Noroad! :thumb:
