DIY Spod- Waytekwire
Part one done! Had to skip a mini fuse it broke of the soldering on the wire no biggy
ImageUploadedByWAYALIFE1394395989.182097.jpgImageUploadedByWAYALIFE1394396008.434481.jpg
Which/whose six switch bay did you use here?
Otrattw has a 6 panel mount like that for $9.00- i believe this is which one he used
or
waytekwire has individual pieces that snap together to make how ever many switch locations you want.
The End pieces are- 44387 $0.95 each
The middle pieces are - 44388 $0.99 each
i believe you have to order a minimum of 5 each
Great job Noroad! :thumb:
Looks like most are mounting the relay box under the dash. Anyone mount it anywhere else like to the firewall in the engine bay? They look to be pretty sealed and would really only get splashed from what i can tell
The relay panel comes with a cover that has a seal. You need to seal up the unused holes in the bottom of the panel, then it would waterproof.
I would strongly encourage you to use shrink tubing - makes a better seal and will not unwind like electrical tape.
thanks i will look into that!! Almost done just need to put all the switches in when i get off work and ill post up the end pics!!
You can pick up various colors and sizes from Harbor Frieght. If you are using a Bic Lighter use the blue flame to shrink it because it is the hottest. I used a cigar torch to do mine.
Good Luck looking good.
R/
Will
R/
Will
sweet i cant wait to finish it today although i was a little sad when i put the gecko switch in that i ordered and it lit up RED :grayno: i ordered green! all the other switches arrive today!
Updated post #133 on Page 14 with correct wiring diagram for the double lit switches from Otrattw.com
Thanks Pastorwug! :thumb:
