Helipilot2
Hey guys, I'm looking at trimming up my fenders to give me more clearance for tires. I just want to hear other people's suggestions and ways of doing it. I have 6 inches of lift and I think I am going with 33x12.5x15s for tires
Just trimming the factory fenders out, putting primer and paint back on them to keep rust out and then putting just basic rubber flares on to cover the tires due to the fact that I have widened it 2 inches on each side so with a 12.5 tire I will have a ton of tire sticking out
Bushwackers flat XJ fenders require you to trim atleast 2" off the sheet metal.
It gives your plenty of clearance for 33's and a 3.5" lift
my brothers XJ
ive got a 1997 xj on 33's with a 6" long arm kit
i first picked up the bushwacker pocket flares but then got rid of them and trimmed the fenders even higher. to clean up the look - i visited ebay and bought a huge roll of door edge gaurd protector in black. anywhere i trimmed - after painting it i laid down the edge gaurd protector trim to get rid of the sharp metal edge. works like a charm!
i can take a close up pic if needed.
That's very similar to what my idea was. How did you go about trimming your rear fenders? There isn't much room to trim without getting into the body
Up travel is definitely a concern with the flat flares. I'm on 4.5" lift an had to take the flares off before my MTR's did it for me. As it was I still nailed the sheet metal when flexed my last snow run with the fenders cut to fit those flares. You can see the the fender damage I took only 20 minutes before this pic.
