Anxious Anvil Build
JKJody
So being that my jeep is mostly built already, it's really not going to be that great of a build thread. I will dig up some old pics and post them up starting from when I took it home from the dealer. I guess I'm starting this because the jeep is beginning stage two of its life. Heres a list of all of my parts.
New jk build
2014 Anvil wrangler sport unlimited*
37" nitto trail grapplers*
Pro comp 7089 17x9*
Warn VR 10000 winch*
Factor 55 pro link*
EVO front bumper*
EVO front D ring mounts*
EVO rock rails*
EVO skid plate system*
EVO rockstars*
EVO sway bar disconnect*
EVO vacuum pump relocate*
Nemesis evap relocation*
Flow-master exhaust*
Poly front 4.5" springs*
Poly front track bar bracket*
Poly front track bar*
Poly front 3" bump stops*
Poly front shock relocation brackets*
Poly front axle sleeves*
Poly front C gussets*
Poly front control arm skids*
Poly drag link*
Poly tie rod*
Poly rear 3" springs*
Poly rear track bar bracket*
Poly rear track bar*
Poly rear bump stops*
Poly rear sway bar extensions
Crown brake lines*
Metal cloak control arms*
Airaid cold air intake*
AEV pro-cal*
AEV tire carrier*
AEV fuel caddy*
AEV rear corners*
Genright rear bumper
Genright license plate mount*
Genright 3rd brake light
Truck lite headlights*
Truck lite anti flicker harness*
Poison Spyder wheel spacers*
Poison Spyder cross member*
Rubicon sway bar*
JKS front sway bar links*
JKS rear sway bar links*
Fox IPF 2.0 shocks*
Fox ATS SS*
Reid racing knuckles*
Dynatrac diff cover D30*
Dynatrac diff cover D44*
Coast front 1310 drive shaft*
Coast rear 1310 drive shaft*
G2 4:88 ring/pinion. D30*
G2 4:88 ring/pinion. D44*
G2 master install kit D30*
G2 master install kit D44*
Teraflex big brake kit
ARB rear locker
Cobra 75 CB*
Icom SP35 speaker*
SPOD
Rigid 20" led light bar
Rigid D2 lights
Led interior lights*
(All of the "*" are the parts I have or are on the way).
ImageUploadedByWAYALIFE1409041738.289967.jpgImageUploadedByWAYALIFE1409041768.655512.jpg
This was an awesome day!
ImageUploadedByWAYALIFE1409041874.357225.jpgImageUploadedByWAYALIFE1409041896.412648.jpg
First thing is first....Trucklite leds!
All the rear suspension bits laid out. Metal Cloak arms, poly 3.0" springs, eVo rockstars, crown brake lines, poly rear track bar and bracket all with grade 8 hardware. Fox 2.0 shocks and poison spyder 1.5" wheel spacers. Jks rear end links and Poly 3.0" bump stops.
ImageUploadedByWAYALIFE1409042284.794577.jpgImageUploadedByWAYALIFE1409042397.961009.jpg
Rear axle pulled and spring perches re welded for better geometry. Rockstars, trackbar bracket and diff cover all bolted up.
ImageUploadedByWAYALIFE1409042595.840432.jpgImageUploadedByWAYALIFE1409042634.661729.jpg
Front axle pulled.
Axle reinstalled with poly trackbar and bracket. Poly drag link and tie rod. Reid knuckles and D30 Dynatrac diff cover.
Jeep with lift complete.
Evo 1/4 pounder installed.
Fox ATS stabilizer installed.
Nemesis evap relocation and flowmaster exhaust going in.
Aev tire carrier installed.
Trasharoo installed and Rubicon tested.
So that is pretty much the up to date stuff on my rig. Before our latest Rubicon trip I installed a poison spyder HD cross member, eVo skid system and bolt on eVo rock rails.ImageUploadedByWAYALIFE1409043844.177403.jpg
ImageUploadedByWAYALIFE1409043872.544685.jpgImageUploadedByWAYALIFE1409043893.296192.jpgImageUploadedByWAYALIFE1409043923.664128.jpg
Rails were approved by my Boston lol.
Old Sluice.
this pic is the latest up to date pic i have. The rails have since been re powder coated and reinstalled.
WOW, what a list............Great build and rig looks AWESOME!!
Thank you. This is my second JK and i wanted to do it right the first time. Was thinking about a long arm with axles but I just don't need all that stuff so this is what we settled on and it works fantastic.
Is that your other built rig in the garage? That is great being able to do everything yourself, especially axels. That would scare the hell out of me taking the whole thing apart........:shock:
No just a friends jeep. Mine old one was a deep cherry red jku sport.
Got rid of her because i wanted a pentistar. And all the work to my current jeep was me and a friend. Mostly him though lol. I just took the pics.
Old one looks great too!! I love all the EVO stuff. I have the Poly track bar and I am impressed with it. I will be looking to get other parts slowly to upgrade. The combo of Poly and Evo, I think is the way to go.
Subscribed! There's nothing better than a built up Anvil rig. Such a sweet color! Keep the pictures coming, I'm loving it!
