My billet rubi build
utiadam
LOSER
Another update:
Stock battery:
Genesis dual battery kit:
I still need to clean up the wiring. I just hooked it up quick for now until my new battery terminals arrive. I will be doing 0 gauge wiring for all battery cables.
utiadam
LOSER
Looks good brother, how was the install on the corners
The corners weren't that bad to install. You definitely have to use ratchet straps to press it against the body. I still need to figure out my tail lights. The turn signals are blinking fast even with the 6 ohm resistors installed.
OscarMike2.0
Another update:
Stock battery:
What did you use on the corner armor(some kind of sealant)? Also how hard was the install of the dynamat and where did you get it? Jeep looks awesome btw!
utiadam
LOSER
This is what I used under the armor:
The installation of the dynamat was very easy because I didn't have to clean any of the surfaces because the jeep was so new. The carpet comes right out as well. The cheapest place to buy it is on Amazon. It's about $140/bulk pack. I used about 4 bulk packs.
