I was driving home and smelt burning oil, I pulled over and there was oil all over the engine compartment and it was leaking from somewhere underneath. Anyone know what could possible be the cause? Or where I start to look first? Thank you much appreciated
That is a ton of oil. I'd clean it all up, and top off your engine again and then turn it on briefly and check to see where it's coming from, should be easy to spot since you cleaned it all up.
Thanks guys, I degreased the bottom and cleaned all the oil up. Inspected as it was running and it turns out I had a 1/2 in crack/hole on the bottom of my oil filter. I changed the filter topped off the oil and no leaking . Just hella smoking for all the oil. Looks like I won't be getting my HEMI yet!!! Thanks for the help/suggestions. Much appreciated!!!!!
