Sessoms14X
This is weird, I just happened to take my hard top off the other day and I told my wife that when I turn up the sound it doesn't seem as loud. I usually listen to it with the volume between 20-25 and it seemed a lot lower.
			So here is a question, Those of us with the factory soft tops are our radios turned down with this wiring all the time?:idontknow:
Wondering the same thing since mine came from the factory with soft top too.
If your Jeep came from the factory without a hard top, it won't have the wiring harness installed either. I don't know if that means your radio is permanently turned down (only way I can think of to check is to play your radio beside someone with a hard top set at the same volume level and compare), but if it is you won't be able to do the bypass that DA RUNT shows in his pictures.
I don't see this as a major issue as long as you can still turn the volume up loud enough to what you want to hear, but it's still useful to be aware of. Another question, does this affect all head units the same way? (I'm guessing it does.)
Because I'm a fucking nerd and tech guy, I just bought a db meter so I can put this thread to the test. Stay tuned, pun intended, for some verified results soon.
Please do. I've been trying to get with my buddy who has a meter to test it also. I don't hear a difference in mine. And I am deaf, least the wife says so. Anybody else that has listened to mine says they can't tell a difference either.
