daystar dash switch pannel
It says for Automatic in the description. Just did not know If it would get in the way of the stick.
Yup, won't work. I looked into that and ending up getting the a-pillar pod.
Offroad Engineering makes one that will work with a manual though. Moby is running one.
I thought I read Eddie used the Daystar panel to put the off road engineering panel on.:thinking:
The reason why you can't use the Daystar panel with a 6-speed is because the rubber boot hits the large switches and activates them. With the Off Road Engineering switches, this isn't a problem as the panel is thin and the switches are small. I'm not sure how things work on a 2011-up as the center stack is designed differently, the shifter lever is bent and now comes with a leather boot.
is that a Daystar panel on your rig?
I don't believe it will work, I have plans for the Off road engineering 12 switch panel (future plans) so I will be mounting it on the overhead plate section of my Rockhard roll cage
So what if you get the daystar dash panel and swapped out the rubber boot for a leather one? I wonder if it would work then.......:screwy:....don't see why it wouldnt
I've been pondering this myself for a while because I plan on have a cage in the near future so didn't want to run the pillar panel....hmmmm
sent from my talkitty box
