dillard09
No...but I should have! I ended up using an Air wrench on the driver side and a regular wrench on the passenger side. Both sides however required a breaking bar to get loose. Those two bolts were the most difficult.
Gotcha. Think I might go and make the purchase of the gear wrenches and just put them in my tool bag. Been wanting them anyways.
wetfootnw
I got my Mopar half doors back from paint and put together last night! Took about 4 hours to assemble them and another hour to mount and adjust.
They look too new!
AlStew
Got the LoD sliders used from a member. Got them installed now time to get some more rust off and paint these!!
Loving these so much more than my poison spider boat sides and I haven't even used them yet!
RockyJk
If you don't mind me asking why'd you switch to the LõD over the PS?
AlStew
The poison spyder one never fit really snug against the body and there was a gap. Water and dirt would collect.
Plus all the dirt that would get stuck inside the slider sucked.
I wanted frame mounted sliders too, with a nice step, so these are perfect for what I always wanted! 👍
Next, we got to get some 37's underneath our rigs!!
AlStew
Painted and installed!
They're still a little wet, but I couldn't watch paint dry any longer 😴 I'll have to touch up underneath.
RockyJk
Ah ok yea that dirt n water would probably cause problems later on
Looks good!
Spudcannons
PSC BFH trail stinger, switch-pros, lockers front and rear, ARB compressor.
shawnrobison77
Louisiana water is actually full of sand! Pulling shafts to install sleeves, locker, gears, and discovered this pretty little mess. Tubes are full of sand, amazed the seal was good and diff wasn't filled
