Spudcannons
Has anyone hooked up the rubicon swaybar to a non rubi jk and still used the electronic disco?
Your best bet is to go with a toggle switch. Get a wiring diagram for the wires coming from the harness and then find the ones you need. There will be extras. I was going to do it and had all the parts but didn't have time before a trip so I bought the no limits. Got lazy, gave away the harness and have been happy with the no limits since.
How were you going to do it? I saw there are 4 necessary power wires one set for the motor and one set for the magnetic pin. The standard operation is a short momentary switch that pushed the disengage then the magnet pin thing holds it open as long as there is power to it.
Curious to see how this is done, I would just get the no limits tho.
I'm giving this a shot then going no limits or maybe the JKS wire one if it works well.
I looked into doing this and found it would have been to difficult for my skills. I went with the EVO no limits which is super easy to use. I did not like how the OEM Rubicon swaybar would always try to reconnect itself every time I sped up. Now I simply turn the knob and it's done. Easy and no worries of it reconnecting on its own.
There is a video on YouTube of a guy who converted the jk smart bar to work with his cj. I would check that out
