LED Tail Lights
BillTheCat
Looking for suggestions on flush mount LED tail lights with backup lights integrated into a single unit.
Thanks!
Oro lite dots can be flush mounted, and I think the genright skins can take them. Evo also uses flush mount, but basically anything will require a skin to mount them. I did run a led tail kit (http://www.rockridge4wd.com/ROCKRIDGE-4WD-LED-Tail-Light-Conversion-KIT-p/pan-5002.htm) but the lights angle out which is kind of annyoing and also if you plan to do corners after, there is not much metal left from the cuts those require.
Maxxima led tails mount on top of the skins, and have a back up integrated which a lot of guys on here are running and happy with. Once again tho, other than shaving the stock tail light holes, you will need corner skins from someone.
http://ecx.images-amazon.com/images/I/91p85VolHcL._SY355_.jpg
That's what I'm looking for!!! Goin' need new skins though.
How do the maximas mount? Half tempted to try them before I cut for the std lights with the gaskets
Closest to flush I've seen without having to install corner armor skins is the MetalCloak:
http://www.metalcloak.com/JK-Replacement-LED-Tail-Light-p/3432.htm
There are 3 holes that you have to drill into the skins for. I'm not sure if you can switch to the flush mount ones if you change your mind.
Yeah it's going to be tough to find flush mounted led tail lights that don't require the use of some sort of corner armor. But all the ones that have been suggested to you here are great quality flush mounted lights no doubt!! I know you said you wanted the break light and backup light all one piece but have you seen these? They are really nice as well just again they are integrated into one light
http://shop.poisonspyder.com/mobile/Product.aspx?ProductCode=41-08-010
again with these you have to use the poison spyder corner guards
