Base model (no sunroof, no Nav, no HID)
- PZEV CBFA engine
- 2 door
- 6 speed manual
- Carbon Steel Grey
- Plaid Interior
- Could include original wheels (detroits) no tires installed
engine warrantied at 22k - story can be found here - http://www.golfmk6.com/forums/showthread.php?t=38362
I am the 2nd owner - bought the car at 3k miles
have all of the maintenance records
have gasoline receipts for the last 2 years
have title in hand
A/C blows cold
stock clutch, no slippage
88k miles
oil changed with full synthetic every 3-4k miles with mostly german castrol, mobil-1, amsoil, motul fluids
fuel filter every 40k
new cabin filter every 20k
new spark plugs every 30k
new OEM drive belt at 80k
have extra rev D DV back up
have superpro trailing arm bushings and inner front control arm front position bushings, not installed
trans fluid changed at 30k, 60k, and 80k
intake manifold warrantied in may 2015 - intake valves were cleaned
new radiator due to leak at 86k
passenger side window motor replaced at 86k
car has new tensioner - bought the parts to do the job but found out had new tensioner - have pic to prove.
mods:
APR stage 1 tune
APR carbonio intake - open filter no cover
Audi R8 coil packs/ NGK spark plugs
Euro Short Shifter
shortened shift lever
ECS dogbone mount
20% rear, 40% front tint
trans fluid (gm syncromesh /redline MTL mix)
APR rear sway bar
Tyrol brake caliper bushings - front
Ate blue brake fluid flush
Hardwired beltronics rx65 - could be worked into price if agreed
Front - EBC yellow stuff - half life - brand new set of pads available
rear - stoptech street performance pads
BFI trans stg 1 insert w/ windo weld fill
Forge side to side quick shifter
windoweld filled shifter bushings
windo weld Filled Lower control arm bushings
set of 5 - 17" enkei Fujins w/ bridgestone re-11 (235/45/17), re070 (225/45/17)
set of 4 - 16" steelies with winter tires (205/55/16 - pirelli winter carving) 1-2 season left on them
1 OEM spare wheel/tire
H&R sport springs / Bilstein B8 mkv shocks
Have all of the original parts if new owner wants them.
asking $14k
possible trades + cash on your side = e36 m3, jeep wrangler, cheap project cars.
IMG_4422 by barische, on Flickr
IMG_4843 by barische, on Flickr
IMG_4425 by barische, on Flickr
IMG_4850 by barische, on Flickr
IMG_4859 by barische, on Flickr
IMG_4847 by barische, on Flickr
IMG_4845 by barische, on Flickr
- PZEV CBFA engine
- 2 door
- 6 speed manual
- Carbon Steel Grey
- Plaid Interior
have title in hand
A/C blows cold
88k miles
mods:
APR stage 1 tune
Euro Short Shifter
ECS dogbone mount
APR rear sway bar
asking $14k
