JAGS
Holy moly. I'm amazed you were able to get it working again. Great info. Now I want to take mine apart to clean and lube.
Buy you beer and a salad if you're willing to do a 2 for 1. [emoji6]
Were you able to clean it out and get it to work again? How much do you charge to help take a look at mine. [emoji6] Wondering if this is my issue?
Lol. I'll help you do yours if you tell me where these pop rivets go on your Jeep.
Hint: Every JK has 2 of them.
Find a cheap plane ticket and im in!!Buy you beer and a salad if you're willing to do a 2 for 1. [emoji6]
Cleaned and greased and so far, knock on wood, it's working. What is happening with yours?
Time for a no-limits!!!Worked on it a while back. When opened the connection it had water and crud inside. Cleaned the connection, dried it out. Re-secured the gasket. The next Time I used it, the light stayed solid for a bit, went back to default as connected and flashing light again.
VIN plates?
Fender flair. Hidden to connect to front support I believe???
Thought it was electrical. Dating back to rubicon. Stopped working after going through stings.
It is a rivet. Jeez.
Pinion crush sleeve.
