mudmobeeler
Not much to a CB install; power wire, ground wire, and coax cable for the antennae. Now, I know nothing about tuning one. I do know you want your antennae grounded well. Other than that it is just hiding the wires. Which if you mount it with the Rugged Ridge one, I would just run them behind all of the plastic trim and either to the battery or the fuse block. You want to be mindful of where you hook it up as if you hook it directly to the battery, you will need to remember to shut it off when the vehicle isn't running. So I usually try to hook them up to something that only gets power when the ignition is on.
