Petzl88
Hello all,
The other day I installed a new Adams 1310 front driveshaft on my JK unlimited. I replaced the transfer case yoke but kept the pinon flange yoke on the axle side. I now have a vibration at highway speeds that starts around 60 mph and then gets worse from there (it is really vibrating where I can hear the pulsations around 70 mph). I am concerned about it damaging my transfer case or something else and I need some help!
I accidentally separated the driveshaft in two, I didn't know that it would just slide apart like that. I originally thought that I may have put it back together in the wrong splines, so last night I took it apart and checked to see where Adams punched two little holes to line up the splines. The little punch holes line up but just by eyeballing the shaft, it looks like it may be out of phase? If I draw an imaginary line from the flange on the pinyon flange, it looks like the top rotates towards the driver's side. But at the transfer case yoke, it looks like the same top point on the shaft rotates towards the driver's side. :doh:
I don't want to go down the downward spiral of changing a bunch of things this week as I am headed to Moab next weekend for some wheeling. I am thinking about putting the stock driveshaft back on unless if I get this figured out in the next few days. Do you see any issues with changing the transfer case yoke back to stock and putting the stock shaft back on? I did put a bead of RTV on the 1-1/4" nut flange and some red locktite on the threads so I don't know if this will mess anything up.
I don't know if the pinyon angle is correct either, and with the Moab trip fast approaching I don't know if I will have time to get new lower control arms, adjust the pinyon angle and keep good caster and handling.
- caster is verified at 4.2 degrees from recent alignment
- JKS 2.5" coils front and rear, measured lift is 2.5"
- JKS control arm correction brackets
![IMG_7040.jpg IMG_7040.jpg](https://www.wayalife.com/data/attachments/163/163067-7f1c7df231de31c0dfb42aa2f8cff816.jpg)
![IMG_7095.jpg IMG_7095.jpg](https://www.wayalife.com/data/attachments/163/163080-507d3a234b460621be36f9c84ed705f7.jpg)
![IMG_7097.jpg IMG_7097.jpg](https://www.wayalife.com/data/attachments/163/163088-431190587f72e2ca1d21d59cd777f055.jpg)
I would really appreciate any kind of guidance you guys can give me!
