Well I guess I am a little different, I have an 8" light bar above the fairlead, a pair of cubes on each corner of the front bumper pointed outward and another pair of cubes on the windshield pillar. I use them all the time either alone when we are out with the pups, or in a group situation. Now I have a different light setup than most, I am running Sierra Dual White/Amber LED lights and I run them in white when running down dirt roads so I can see a little farther but when just crawling around I run the amber and I can run them behind people WITHOUT blinding them.
Here is an older pic of the front, the bar is correct but the cubes have been replaced is the only difference, the lights are in the correct locations. I have found that with the amber lighting there is less shadowing and less glare which makes it really easy on your eyes.
To the OP, if you want extra light while out playing in the dark you will have a lot to choose from so look at what is out there, do a little research and get what you think will work for your situation.
