Cut the pinch seam and rubi rock rails. It was hot as balls today, so it wasn't as fun of a process as it should've been. But it's all part of the master plan!
ImageUploadedByWAYALIFE1466965945.980587.jpgJKS Adjustable front track bar, EVO draglink flip, Synergy tie rod, synergy track bar brace. Not too bad of a process either
ImageUploadedByWAYALIFE1466984167.014516.jpgImageUploadedByWAYALIFE1466984187.708273.jpgImageUploadedByWAYALIFE1466984216.520623.jpgImageUploadedByWAYALIFE1466984254.756831.jpginstalled bed tread today to see if it helps with the dog hair. I'll post pics in a few weeks to see how it did. Easy install too.
I bought 1 ton's for the 2 door and started removing the brackets. Looking to have most everything stripped and ready for cleaning/existing mounting bracket removal tomorrow!
I've had this clunk noise coming from what I thought was the trans mount but with further inspection I found my rear lower control arms had loose bolts. It wasn't so loose that I could turn them with my fingers but loose enough for things to shift under a load. So I went and Tightened all the suspension bolts.
Just added this pic to my build thread but thought I'd share here as well.
-3.5" Rock Krawler Flex System with Bilsten 5100's
-Procomp 7032's with 35" BFG KM2's
Pic is of day I picked it up to now
