Shock length
REK
I have a 2013 wrangler with a 2 1/2 inch lift and I need to replace shocks but the rancho has them for 2 inch and 4 inch lift. Can you use 4 inch lift shocks on a 2 1/2 lift
It really depends on your bumpstops. To get a concrete answer, you need to take some measurements and determine if the collapsed length of the shock is less than the length of travel until you hit the bumps. If so, good to go.
If you are looking into Rancho i suggest you contact Matt our Rancho rep here on the forum he will guide you. This is what i did.
Use what suggest with our 3" system
RS999329 (front)
RS999330 (rear)
Rebate info:
Save all boxes if you buy online, you will need the UPC from the boxes.
READ the whole rebate form and make a copy for your records.
http://www.gorancho.com/promotions
Thanks Matt
