Frydaddy
2013 JKUS auto on Kanati 35" (34.5" actual) with 3.21:1?
I have not found a single cross reference to whats going on in my differentials.
- Build sheet from Jeep Site (linked) says 3.21:1
- Jacked up the rear and spun both tires once, drive shaft spins about 3 1/4 turns, sounds like 3.21:1
- at 70mph, and getting the torque converter to lock, it shows about 2000rpms, the below chart says that is 3.73:1
- I can almost guarantee cracking open the diff will show 3.21:1 considering the tire spin test.
The history is fairly straightforward. It was a rental jeep in Hawaii for two years. Then bought at auction and a dealer slapped on some tires and pucks under the springs. I have the Superchips Flashpaq and updated the tire size, the speedometer matches GPS tests.
This concern all comes about because I still don't like the way it shifts (shoulda' got a stick, I know). I do a lot of highway driving 65-80mph, and its almost constantly shifting. The general consensus is that 4.10 would restore the stock final ratio, and 4.56 gives a good ratio for highway mileage and crawling.
Looking at the chart below. I have two situations that might happen.
- If i fudge the tire size to match RPM with Ratio (30"), 4.56 will put you a little high at 2968rpm, and 4.10 gives a nice 2669rpm
- If I fudge the ratio to match Tire Size with RPM (3.73), 4.56 will be perfect at 2544rpm, but 4.10 is a laughably small change
TLDR: All evidence shows 3.21, EXCEPT real highway results suggest 3.73.
Thoughts?
Edit: Link broken. Follow the link, then click on "Equipment Listing"
Thoughts?
