Thanks guys. By the way on a side note - installing the spacers was not nearly as easy as I'd hoped it would be. For one, apparently jacking up the rear diff jacks the driver side about twice as much as the passenger, so I needed a second jack to get the passenger shock mount jacked up to get that tire off, then I couldn't get the axle to droop enough, I got the springs out simply enough but getting the spacer in was a PITA because even with grease all over them they didn't want to pop into the hole with just my pressing them in. I had to get the coils back in and compress them to force the spacers into the mount hole. But because that left me working with 2-3" less clearance, it made it so that I had to compress the springs that much more to get them in.
So I didn't figure on needing a coil spring compressor but wished I had rented one before starting. I ended up using a pair of ratchet straps to help compress the driver side, sketchy as hell and wouldn't do it again but managed to make it work. Then I put it all back together and ran up to autozone to rent a compressor for the passenger side, but that was difficult as hell because there's very little room to work with on the passenger side because of the track bar.
Long story short - I think if I had started out by removing the track bar and sway bar links, I might have made the job a lot easier - but it's one of those "well, if I had to do it again...." things.
Too many horror stories of people and coil compressors...stay away from them.
I had a little bit of the same issue when putting my new coils and spacers on.
It's much easier if you raise the Jeep up as high as possible, put your jack stands on the frame, and disconnect the sway bar links and shocks to get enough droop.
Also being mindful of your brake lines, wheel speed sensors, etc. I actually pulled the calipers off the rotor for the rear to be able to get my larger spacer installed.
It takes a little more time, but makes the install much smoother. I know you've already got yours installed, so just a little input for the next guy
Jeep looks good :thumb: nice to see other 2 doors keeping it real
Buying a set of LARGE jackstands helps also, you can get the vehicle a lot higher so the axle drops even lower.
What all is really necessary to disconnect though? Does the track bar limit the droop any or is it just the shock and the sway bar? I started to disconnect the shocks but I had such a hell of a time getting one off because it was so cold it makes the bushings really stiff, I gave up on the thought of disconnecting the rest.
I guess this will be good advice and a learning experience for when/if I replace the coils all around.
Well, I mean... if you already have the springs out... you should just go Dynatrac 60/80 combo and EVO coilovers. :crazyeyes:
So I was taking a look at the ripped off rear fender liner and flare last night, looks like I'm going to need to get new plastic hardware from the dealer as some of the old stuff is now broken. Makes me wonder if I should just replace both the rear flares with aftermarket options instead [emoji851]
if it were me id trim it while its off as long as it salvageable, ditch the inner liner and then buy the new hardware to re-install, sure it will be a lot cheaper, i have no idea how much those clips cost that connect to the body but i cant imagine to much. I do like some aftermarket options but i don't like the price, especially when you've already paid for the stock fenders.
I may just do that. I was just looking at quadratec and the hardware is pretty cheap. Will probably be a lot easier to reattach without the inner liner, too. May just get a rattle can of bed liner for that.
if you decide to trim the fender you have to ditch the inner anyway but I know a lot people paint the inside black, i did not, because well my jeep is black. if you really wanted to i imagine there are inner fenders out there for sale but idk. it its just the outer and trimmed its snaps on and off super easy.
yea probably good to mask the one on there so you can kinda see what it'll look like on the jeep.I'm guessing the best way to trim it now that it's off would be to mask off the flare on the other side and use it as a template for the one that's already off.
