JeepinDingo
I recently upgraded to 35s and I'm planning to get a programmer soon. But all this MPG stuff has got me thinking...
So everyone claims to loose MPG when they get bigger tires, pretty common knowledge. I think everyone also agrees that MPG will go back up a bit after you program the new tire size. I'm not trying to debate these things, I'm just trying to understand the facts on how people get this data.
With larger tires and no computer correction people agree the speedo will be slower than your actual speed. This is because with larger tires you travel more distance for the same amount of wheel revolutions. But if this is true for the speedo it will also be true for the odometer. Therefore, if you calculated your "bad MPG" using the milage shown on the odometer, it is inaccurate. Your odometer may show 200 miles traveled, when in reality you may have traveled 225 (these are made up numbers used to illustrate my point).
Using these made up numbers for math:
If it takes 15 gallons to go 200 miles.
200/15= 13.33mpg
If it takes 15 gallons to go 225 miles.
225/15= 15mpg
So you correct the computer for the new tire size, now your odometer shows 225 miles instead of 200 for that same tank of gas. And there you have "better" MPG.
The only way to get accurate data is if you track the miles driven using something other than the jeep odometer (maybe there's an app for that). Then calculate MPG that way, both before and after the computer correction.
Maybe you guys already know this and I'm just late to the party, but I haven't seen it discussed. Hopefully this is some good food for thought.
I'd love to hear if anyone has this type of accurate data. But I will find a way to accurately track my mileage now, then update this post once I get a programmer.
Sent from my SAMSUNG-SM-G891A using WAYALIFE mobile app
200/15= 13.33mpg
225/15= 15mpg
