The Build & Travels of ORION
Got the Evo Fascia, Rock Hard License plate relocate kit and Hitch installed. Some minor cutting, grinding and modifying was required....
A little tape so the nut wouldn’t drop into the frame....
I wasn’t happy with how far the plate stuck out with the stock wheel.... so change of plan. I raised and reversed the tire bracket so the receiver was now at the top center spoke. Only had to oblong a couple holes in the bracket.
Then I welded an extension to the Plate holder so the set screw could be used.
Its actually easy to reach the bolts with the tailgate is open...
Keepin it Tight...
Really happy with the rear now... clean and simple.
The bumpers look a little funny with no lift and small tires, and no Winch... but still a huge improvement from stock...
Next will be to trim the fenders which will help balance things.... enjoy the Jeep for a While.... then Lift & Tires.
