Looks good.
Did you get the other toys installed? Hi-lift mount, evap skid.
I got the hi-lift mount installed a week ago but can't find my hi-lift after the move. I have no idea how something that big "disappears" but all the boxes are unpacked and it's not in the house. Here is a pic of it without a hi-lift
Today I finally installed the EVO evap skid. I have to say this is easily the most well engineered evap skid in the market (if you have an off the shelf or stock exhaust). I found that most folks could do the install in 15 min without even disconnecting any hoses. IMO it's also one of the nicest looking skids out there.
I found that the install on my rig wasn't so straightforward. Before sending the rig to ORE, I had a custom muffler installed that is much larger than the standard magnaflow or dynomax kits out there. I didn't want the droning and had a large stainless muffler installed. The exhaust is awesome. It doesn't drone and sounds fantastic. Well, it turns out that my evap skid and muffler come in contact so my 15 min install became a 1.5 hour install.
First came the measure once poorly and cut many times cut:
Before:
After:
Then painted before test fitting:
Then realizing I had to cut way more than I thought:
Finally installed:
My skid probably isn't quite as strong as those who don't have a corner cut off, but it is still supported well and is definitely a ton stronger than the factory skid/mount by itself.
