dchew
For me this is a big undertaking. Oso is our 1-month old 2013 Billet Silver JKUR, manual trans. Here are the plans:
EVO high clearance long arm kit
EVO bolt on coil over front/rear
AGM sliders for King c/o
EVO Drag link flip kit
EVO Axle C gussets
EVO Rock sliders
EVO rocker skins
PSC steering assist w/ new power steering pump kit
aFe CAI intake (to make room for the PSC reservoir)
37” Nitto Trail Grapplers
17” Hutchinson beadlocks
Spydertrax spacers (?)
Terraflex tire carrier
JE Reel 1350 front driveshaft
RCV front axle shafts
Expedition One front bumper
EVO Protek skid
4.88 gears
Trucklite LEDs
So far I’ve installed the Trucklite LED’s (done the first day it came home). Also the aFe cold air intake:
Stuff from EVO arrives:
Tires!
I’m lucky in that a very good friend has a well-equipped garage. Two lifts, a whole bunch of tools and a lot of experience building cars. You can see some of his work in the background of these pics. I also have a friend who is a very good certified welder.
Jeep goes up. No, that Weiand blower is not going in the JK
Playing with on of the rims
The combination of the EVO high clearance long arm kit (weld-on) plus the bolt on kit is a bit tricky. This is essentially Rubicat’s set up if I’m not mistaken, but they have changed some things in the bracketry since Eddie’s build. I started the major work Sunday. The gas tank was tough. I swear each connector is different and each one a unique learning experience! Sunday we basically got the Jeep up, outlined a plan and removed the gas tank.
Gas tank off finally!
Since I have to go out to have the gears done we decided to go ahead and completely remove the rear end. That was tonight’s job. Removing it will also allow us to re-true the housing if necessary with all the welding that goes on the rear end. Also a note about the rear drive shaft: There are two holes in the back of the connection in front of the pinion flange. We used a small extension rod to tap out the driveshaft. By the way, a D44 rear housing is heavier than you might think…
Oh no, what have I done??
Tomorrow night we start cutting.
Dave
EVO Axle C gussets
EVO Rock sliders
EVO rocker skins
EVO Protek skid
4.88 gears
Trucklite LEDs
Tires!
Dave
