Oso Build Thread
OverlanderJK
Resident Smartass
attachment.php
Those welds look like garbage.....
:cheesy: Kidding! Nice welds!
dchew
Well, I wish I could take credit for those, but all the welds you see are on the bracket as it comes from EVO. :blush:
Haven't welded anything yet; those brackets are just in place for fit. It will be a while; we have to remove them, clean it all up for welding, then paint behind. I'm trying to figure out the best way to protect the frame underneath these brackets. Obviously we can't paint where we are going to weld, but I don't want a big bare section underneath the bracket either. So much salt is used where I live...:(
I think after cleaning it up we will paint it all, then regrind only the places right where the weld will be. Then after welding paint again. Anyone have a better plan?
Prime8
Sounds like a good plan. Every time I work on my rig I have salt/corrosion in mind too. As matter of fact, I keep semi gloss Rustoleum or flat black primer and wire brushes with me any time I'm working under the jeep and I clean up rust as I go.
arashi
Nice garage!!! I love the other car in that garage... Good luck with your modif :)
dchew
Got the front end off tonight and removed the front axles. We are going to haul off the housings to get them re-geared with 4.88's. Traveling tomorrow till Wednesday.
Prime8
You bet! Looks great :thumb:
So did it take two quarts?
Well, the measuring technique specified in the ARB instructions is highly subjective and inaccurate. So I googled it. 1.3 quarts was the consensus with the locker. Put in about 1.3 quarts and it registers on the dipstick... So I hope it's adequate!
dchew
Well believe me I nobody wishes this was going faster than me! Frustrating evening last night between spilling a whole set of drill bits into the garage drain crock and breaking a few dozen dremel disks. The front coil over mounts are in, but the passenger side was a real bear. I don't know if Jeep changed things in 2013. I had to cut away so much plastic to the point of opening a hole into the battery compartment. Even then I still had to grind off the corner of the EVO tower (or else raise the battery). The rear top corner of the mount was hitting the front edge of the battery. There is a front plastic clip on the battery that helps hold it down. Not on mine any more. :grayno:
I will post picks later today once I clean up my cuts and touch up the tower. Not sure what to use to close up the hole. It is about 1.5" x 2.5". Maybe structural foam? I doubt plastic welding will stick to that material...
Dave
Prime8
Plastic wrap. Definitely plastic wrap. As far as encountering unforeseen install problems that really stretch build time: welcome to EVO.
Prime8
Saran Wrap or Glad Clingwrap? Which works better??
:cheesy:
Haha. Well if you are trimming out the softer plastic inside the wheel wells, I'd make a patch with that and use either gasket maker or that "plastic weld" stuff that actually partially melts and bonds the plastic. You can even try using a torch on a couple scrap pieces to see if it will melt together, instead of just burning...
piginajeep
The Original Smartass
I had to cut away so much plastic to the point of opening a hole into the battery compartment.Dave
this is normal to grind into the honeycombs (ribbings) on the battery tray. No reason to cut the part..
dchew
I know the ribs are normal. But see the photos below. If I mounted this wrong I would love to know before I put it all together! :blush:
I ground the top rear of the mount. If I didn't it would have run into the battery. There used to be a battery mounting clip to the right of the battery that I also had to remove. I know I didn't have to trim quite as high as you see directly above the mount, but once I knew I had to breach the battery area I wanted to be sure I knew what I was cutting. So I cut it flush with the area to the right. That will also make it easier to cover it up.
I might have been able to avoid cutting into there if I ground a lot more off, but I was worried about maintaining the integrity of the coil over mount. Not sure if anyone has installed this yet on a 2013, but maybe they changed that area from 2012...? Or am I doing something seriously wrong?
dchew
Checked with Andrew; everything looks correct. Either my JK is goofy or they changed something for 2013. Got everything on the passenger side cleaned up and repainted the C/O bracket after grinding. I'm leaning toward bending and painting some sheet metal to cover up the void.
Anyway, bumper off, vacuum pump relocated, removed the front control arms, started removing the necessary parts to tackle the PSC steering assist. I think it is best to do that now while the front end is apart. Looks like the reservoir will fit with the aFe CAI! if I can just figure out a way to mount it :yup:
Today we will cut off the front C/A brackets and try to fit the EVO high clearance fronts. That means dealing with "The Bugle" exhaust loop. I would have gone for the aFe down pipes to delete the bugle, but I understand it doesn't work with the Protek skids.
