01WJ build
Looks good. I thought about going this route myself. Haven't decided what I want to do yet but that is definitely nice and clean looking.
Thank you. The install wasn't difficult at all and can be done by anyone with basic power tool skills and common sense lol. Very easy to follow directions
Here it is done and a then (3 months ago) as now. Still have a long way to go it seems lol
Not hard at all I had to make an opening in the grill due to my lightbar location and I put the plug adapter near the rollers
Blew the head gasket so now I'm gonna give this a try #jeepproblems
Be careful with that stuff. Even if it DOES fix your leak, keep a close eye on your temps. That stuff can cause blockages too. After you run it through your system for awhile, I would change the tstat no matter what.
I'm about to do a motor swap not sure if I wanna keep the v8 or get the 4.0 v6
Do some good research. The V8 has a lot of power that you'll lose if you go to the I6, however, the I6 4.0 is a great motor. If you do go to the 4.0 you will probably want to re-gear.
