ERAUGrad04
Thanks for sharing jk12blk! This is the cleanest mod to the airbox I've seen. I just bookmarked your post so I can try to duplicate it when/if I get around to hydro assist.
Same here, his came out nice. Seen some real bad hack jobs.
I just took it apart to provide some additional pics. Hope this helps.
View attachment 132900 View attachment 132901 View attachment 132902 View attachment 132903 View attachment 132904 View attachment 132905 View attachment 132906 View attachment 132907 View attachment 132908 View attachment 132909 View attachment 132910 View attachment 132911
LOL. Unfortunately, I did not do the work. However, seeing it complete makes it look doable for sure. It actually fits great, but things get a bit tight when I have pull the air intake tube closer to the radiator to install those two bolts that hold the tube to the radiator shroud. It pulls the entire assembly towards the front of the jeep and the airbox then presses against the res which pushes the res into the radiator overflow tube (just a hair width away). It's fine, but it's a snug fit. The fix would be to grind away at the airbox where it meets the curvature of the res, but I don't think it is worth the effort.Man that looks good. You're only a couple hours from me. I'll drop the jeep off on Saturday.
Thanks for taking the pics.
