I'd have to double check, but I think the 3rd brake light
Cut the third brake light down, and zip tie it. There are definitely better ways that others have implemented, but this is working for me, for now. You'll also probably find that then bumper is in the way and will also need to be removed.
Push the tire on (this will compress the isolators a bit more than previously) and get the lugs threaded. Then tighten them down and it will snug the wheel and tire up so it doesn't bounce around while driving.
I've got my 35/12.50/17 mud grapplers on OEM wheels hanging on the stock carrier for over 6 months and 10k miles with no issues.
You can space out the spare wheel a bit further and extend your isolators if you don't want to cut down the brake light or remove the bumper. Just make sure the tire is snug up against the isolators to keep it from moving.
I'll try and go take pics of mine tomorrow once it gets light but the only thing I know I hit for sure is the cb mounting point attached to the upper passenger side of the carrier. Antenna is on a spring so it gives it a slight forward bend.
Sorry to bring this thread back, but I didn't find my answer reading through it all.
I have 35/12.50/17 Nitto Trail Grapplers, on the stock JK wheels, and want to put my spare on the stock carrier.
I don't have the money right now for an aftermarket tire carrier, but I would only be putting it on the stock carrier until I have the funds to upgrade.
The 35 on the stock wheel doesn't have enough backspacing to fit on the stock carrier. Can i use a wheel spacer on the stock carrier, and if so what width would I want?
Stock wheel no spacers, POS rear bumper removed. Running 35x12.50/17 Toyos View attachment 229476
It will be very tight against rubber isolators on gate but that's what you want.
Do you have a third brake light extension?
Another spare tire bump stop solution. Rubber stoppers from Lowes to extend the factory ones.
View attachment 119262 View attachment 119263
I wish I had as much luck as people are posting. My tailgate has started to crack and rattle and pop over every pebble on the road. Stock carrier did not work for me. :/ I'm running it with no spare right now and it has not made a sound since.
View attachment 232643 View attachment 232644 View attachment 232644 View attachment 232645
Sent from my LG-H900 using WAYALIFE mobile app
I did yes. But this issue started with my duratrac 33s on kmc xd122. The 35s made it worse. I drove it for a day and had to pull it off.Damn! I'm hopefully ending up with the STT Pro's by end of next week and was planning on stock carrier... you have 35's? Well isolated?
I have a 35x12.50 Toyo on my stock tire carrier. I extended it out to get it off the bumper so the factory isolators don't even touch the tire so I ordered isolators that are cut to fit, didn't have to cut them and it's still not as tight as it should be, hitting a big enough bump causes the tailgate to rattle on the latch, any ideas?
