Jaimegomez8
Noob question but I've been doing a lot of research before I go and purchase a set of wheels, that being said I do I need to re gear my 2015 jk or will I see some damage down the road?
3.21, although I've heard people using super chips or other computers, what is the purpose of that?
I have 35s and stock gears in my sport 4 dr. I have no problems and don't plan to regear the dana 30. I have noticed power off the line but not enough to feel the need for new gears and i drive 30 minutes to school one way. I would think differently if I had a d44 upfront but I would also have 37s. Just my 2 cents.
Thanks I think I'm confident enough to get some 35's I don't commute that much a day so I don't think it would be a problem for me, thanks for the info
fixed it for you ;-)Procal by AEV or equivalent before you have the 35s installed!
Wow! I can't imagine running 35's with 3.21 gearing! That's sounds horrible.
I'm on 35's with 4.10 and a banks auto mind programmer on sport mode to get power back closer to stock and make the computer adjustments that are needed for the tire size change.
I say plan on regearing if you want your jeep to be able to move when the light turns green and four low not to be like four high.
Drive a jeep that is regeared and you will feel differently.
I started out with 3.21's in a 2014 JKU running 35's. Ran it like that for about 15,000 miles. Around a flat town, it's less than ideal but still manageable. Where it will become the bane of your existence will be in hills with even a little bit of altitude thinned air. You. Will. Hate. It.
I spent the money and went with 4.56's. It is, to date, the best money I have spent on the Jeep. It is only a slight advantage off-road. Where they shine is on the highway. I actually gained about 2.5 MPG's when I switched. The reason being is that where I live, there are lots of long, rolling hills on the highway. Before, the transmission would downshift to 3rd at even the slightest incline. Now I hold 5th for everything except the steepest hills. I've done the math, the 4.56's will pay for themselves after about 50,000 miles due to the MPG improvement. (that's also how I justified it to the GF).
Bottom line, it's a boring, un-glorious way to spend $1,500+... But it's worth it.
