A Pillar Rattling Noise
spencerd45
I just picked up a used 2014 JKS with some miles on it. After having it a few weeks, I have noticed the top left corner of the A pillar where the roll bar meets the windshield is making a rattling noise. I took off the trim and tightened all the bolts and the noise is just as bad as before. Anyone else have the same issue or have any ideas how to stop it?
Thanks again,
Spencer
I thought it could be the plastics making the noise so I removed them and it still rattled. I tightened the bolts and put the plastic trim back on and the noise is exactly the same. Not sure what else to try
if you have a hardtop, there's a bolt under the drivers side top that holds the back portion of the top down. That bolt would come loose on mine, I put some Teflon tape on it to keep it from working loose and rattling.
