Maybe you have a tire that's way low.. you're low tire pressure light is on?
Otherwise ABS/Traction control could be wheel speed sensor or if you've had a lift installed it could be due to that or several other causes. Anything worked on or changed?
You can run down to your local Oreillys. They have free scan-capability for ABS systems. They can at least get you a code.
Yeah... this is your best option.
Mine was my pcm, traction cotrol system and abs module all went bad, estimate to fix all was $2300.00 my jeep will not come out of limp mode
Update for those of you that are interested...
What happened was somehow both front speed sensor wires had come unclipped from the last bracket closest to the sensor leaving them dangling.
Don't really know how this happened at the same time, maybe from last trail run or from high pressure wash afterwards, don't really know. Anyhow, the wires insulation rubbed off over time and shorted out.
Guess I need to keep an eye out for this in the future. Thanks for all the input everyone.
