Adjustable track, flip kit ,or both??
drwfaulk
ok so i have been planning this for a while. 3" plush rides ,RS9000 , control arms(with JJoints), rear trackbar, SS break lines, bump stops. I just cant find the info that i need to make a decision on the front track bar. I need some insight plz!!!
P.S. 08 2 door x with 35s and budget boost
With 3" of lift, you would benefit from a drag link flip/front track bar relocation bracket. With it, you will not need an adjustable front track bar. For whatever it's worth, you could just get by with a rear track bar relocation bracket too.
Thanks Eddie, is there anything that im missing in the set up above?
Well, front drive shaft for starters. Being that you have a 2-door, rear drive shaft eventually and adjustable rear upper arms so that you can set your pinion once you do.
