Canvasback
HI all .... Looking for some input here.  I had my Evo 2.5 lift installed by a shop this last week and heard an unusual sound just going over some speed bumps at the store. After isolating where it was coming from (passenger side ) I took a look.  The front right spring is flexed pretty good just in a normal parked position. The right spring coil is rubbing the front of the bump stop and the front plastic shield on the king shock is almost touching the coil. I measured the control arms and the driver side is adjusted shorter than the passenger side by about 3/4".  My system has lower control arms only.  I have attached my alignment specs for before and after. Any thoughts on solution?
