You can do it yourself with basic hand tools.
http://wayalife.com/showthread.php?3861-Basic-Do-it-Yourself-Jeep-JK-Wrangler-Front-End-Alignment
Agreed ^^^
Unless you have adjustable components throughout your Jeep, the most a shop can do is take your money. Even if you have adjustable components, you can do just as well with my write-up above and for free.
I've glanced at this thread before but I'm not experienced at all with this kind of stuff. It's not off that bad but does pull slightly to the drivers side. I do not have adjustable components.
Then the most an alignment shop can do is center your steering wheel and adjust toe if needed, plus take your money. Try rotating your tires. See if it helps. What steering stabilizer do you have?
Stock stablizer. I'll check out the thread and see if I can straighten it out.
Removed my prior post seeing you don't have adj arms. I had a slight radial pull to the left and swapped the left front tire to the right front and all is good. Maybe start there first?
So is your wheel off center?
Yeah it's a little off and pulls so I know it's not just the steering wheel.
He has adjustable lowers at least with the enforcer. The adjustable components they are talking about are track bars.
Do you have a procal? I'd try centering your wheel and rotating tires first, it's free. Good luck with sorting it out
